hp pavilion 15-cc023cl Motherboard Replacement
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect SD and USB card cable.
Stephanie Henry
crwdns2935283:010/02/18crwdne2935283:0
1.122 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G6, Munoz Fall 2018 crwdns2935289:0Eastern Washington University, Team S2-G6, Munoz Fall 2018crwdne2935289:0
EWU-MUNOZ-F18S2G6
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - crwdns2934203:0crwdne2934203:0
How can i get this model motherboard
Adeyinka Alasi - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,620
