Replacing the thermal paste on a graphics card
  1. Replacing the thermal paste on a graphics card, Exterior view: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In this accessible tutorial, I will show you how to replace the thermal paste on a graphics card. The method applies to all cards.
  2. Replacing the thermal paste on a graphics card, Remove the screws securing the heatsink-fan assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the thermal paste on a graphics card, Remove the screws securing the heatsink-fan assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will have to remove the Phillips screws to detach the heat sink and the fan from the card. Some cards may be equipped with a shroud, but there isn't one on this one.
    • The screws to be removed (Red Circles)
    • I also advise to unscrew the screws in an "X" pattern (a turn or two at a time for each) so that the force exerted by the screws is very uniform and does not damage the card.
  3. Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the thermal paste on a graphics card, Disassembly of the heatsink/fan assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It is important to remove the fan leads with care not to damage them. Disconnecting them can be tricky.
    • Graphics processor (GPU) in my case, it's a Radeon HD 7790
    • Video memory chips (VRAM) in GDDR5, on this card we have a total of 1gb of memory spread over 4 256 MB chips.
    • 6-pin 12v connector for power supply.
    • The voltage regulator modules (VRM) permit the delivery and regulate the power supplied to the GPU, VRAM etc ...
    • Connectors for video and audio such as HDMI, DVI and Display Port.
    • VRAM dedicated thermal pads.
    • Heat sink to dissipate the heat generated by the GPU VRM's and VRAM.
  4. Replacing the thermal paste on a graphics card, Replacing the thermal paste: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the thermal paste on a graphics card, Replacing the thermal paste: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the thermal paste on a graphics card, Replacing the thermal paste: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old thermal paste with a cotton swab and isopropyl alcohol. Then, apply a new dose of thermal paste (it's inexpensive).
    • After replacing the heat sink on the GPU, the thermal paste will spread.
    • Be careful not to use too much or too little paste. To be sure of the amount, you can spread it out with a card.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Shibe
crwdns2935283:005/21/22crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
Do i have to replace the thermal pads too?
Mateusz - crwdns2934203:0crwdne2934203:0
I'm sorry, i was a bit busy, but if the thermal pads are still intact and making contact with the chip and heatsink, you can keep them.
Shibe -
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 87
crwdns2936753:030crwdne2936753:0 379
crwdns2942667:0crwdne2942667:0 4,739
