eufy Security SpaceView Monitor Antenna Replacement
  1. eufy Security SpaceView Monitor Antenna Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Security SpaceView Monitor Antenna Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Antenna Replacement, Lift the display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Antenna Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
  6. eufy Security SpaceView Monitor Antenna Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Security SpaceView Monitor Antenna Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
  7. eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
    • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
    • Lift the motherboard and disconnect the antenna connector from its port.
    • The motherboard is free from the housing and can be replaced.
  8. eufy Security SpaceView Monitor Antenna Replacement, Antenna: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the #00 Phillips head, unscrew the two screws fastening the antenna wire at the top right hand side.
  9. eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the tongs that are connecting the antenna to the fastener.
    • Pull the fastener off off the tongs.
  10. eufy Security SpaceView Monitor Antenna Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device around and pull the antenna from its connection point.
Declan Andrews
crwdns2935283:010/31/23crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023crwdne2935289:0
UMASSD-GULBRANDSEN-F23S2G5
Where can I get a replacement part for the antenna?
Vincenz Marschall - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 1,400
