If your eufy RoboVac 11's side brushes are stuck or having trouble moving debris towards the rolling brush, looking through this guide may be beneficial. Replacing the side brush motors requires some finesse in taking the RoboVac apart. However, the replacement itself is rather simple.
Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
Remove the top plate from the body of the device.
Unplug the bumper from the motherboard.
Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
Unplug the cables from the motherboard.
Remove the 10 mm side brush motor screws with the Phillips #1 screwdriver.
Remove the side brushes.
Remove the side brush motors.
