If your eufy Robovac 11 isn't powering on, taking a look through this guide may be beneficial. Replacing the battery is very simple, requires only a couple steps, one tool, and can be completed fairly quickly. In between removing and replacing the battery, cleaning the compartment out is recommended. The battery compartment has a tendency to collect dust and debris, so cleaning it out may also help the battery last longer.
Remove the 10 mm screws using a Phillips #1 screwdriver.
Use your hand to firmly grip the Molex harness and push the clasp open to release the male from the female port.
Remove the battery from the vacuum.
