This guide will explain how to replace the side brush of the eufy L60 vacuum (Robovac L60). If you are thinking of replacing the side brush, you can purchase one on the eufy L60 website. The side brush plays an important role in reaching hard places such as the outer sides and corners of walls that the regular brushes cannot reach. The most common symptoms that the device will experience is lack of spinning, lack of debris being picked up, and a prominent clicking sound that you can hear from the side brush. An article that may be relevant is this one from the eufy L60 website.
Turn the eufy L60 vacuum upside down.
Use a Phillips #2 screwdriver to remove the 5.8 mm screw from the grey spinning brush on the bottom.
Give the brush a slight tug to pop it off.
