This guide will explain how to efficiently replace the bumper located on the bottom of the eufy L60 vacuum (Robovac L60). If you're considering a replacement for your clogged brushes, you can easily purchase some through the official eufy L60 website. The brushes are essential for cleaning surfaces and efficiently picking up debris. The most common symptoms signaling your brushes need replacement are a lack of spinning and lack of debris being picked up. A user guide that may be relevant is one from the eufy L60 website.
Flip over the eufy L60 vacuum and turn off the power.
Use the Phillips #2 screwdriver to remove the six 2.4 mm screws positioned along the bumper.
Lift the bumper slightly and jiggle it free.
