eufy Clean RoboVac G32 Pro Motherboard Replacement
  1. eufy Clean RoboVac G32 Pro Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your device is turned off.
    • Flip the device upside down on a flat surface.
  2. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 10 mm screws using a Phillips #1 screwdriver.
  3. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover of the battery.
  4. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the battery using the white straps on the side.
  5. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the battery, pinch the clips on the side of the white connector.
    • Using a spudger, push the part of the connector inside of the Robovac away from the white connector on the battery.
    • Pinch the clips hard; they may be a little stiff.
    • Remove the battery from the device.
  6. eufy Clean RoboVac G32 Pro Motherboard Replacement, Rolling Brush: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the clips at the bottom of the device that are indicated by the downward facing arrows.
    • Take off the rolling brush cover.
  8. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the rolling brush up on the right side. Remove the rolling brush.
  9. eufy Clean RoboVac G32 Pro Motherboard Replacement, Wheel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  10. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 10 mm screws using a Phillips #1 screwdriver.
  11. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the wheel.
    • Lift firmly but gently as the wheel's connection to the motherboard is delicate.
  12. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the spring from the wheel.
  13. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard wiring from the wheel.
    • Pinch the white cable connecting the wheel to the wiring and pull.
    • Remove the wheel from the device.
  14. eufy Clean RoboVac G32 Pro Motherboard Replacement, Bump Sensor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement, Bump Sensor: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement, Bump Sensor: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the device so the underside is facing up.
    • Remove the eight 9.3 mm screws securing the bumper brackets using a Phillips #1 screwdriver.
    • Remove the bumper brackets.
  15. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bumper off of the device gently.
    • Use your fingers to disconnect the 8 pin connector.
  16. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 10 mm screws using a Philips #1 screwdriver.
  17. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bump sensor off using your fingers.
  18. eufy Clean RoboVac G32 Pro Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 14 mm screws with a Phillips #1 screwdriver.
  19. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands to separate the two halves by lifting the cover from the end that has the brush, as the cover is still connected.
  20. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 9.7 mm screws securing the motherboard with a Phillips #0 screwdriver.
  21. eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eufy Clean RoboVac G32 Pro Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all connectors attached to motherboard.
    • Using your fingers, pull the connectors away from their ports by the plastic bit of the wire.
    • Pulling from the wires themselves could lead to the wire(s) loosening from the connector.
    • Remove the motherboard.
Manuel Chias
crwdns2935283:009/19/24crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-5, Coppersmith Fall 2024 crwdns2935289:0University of North Texas, Team 2-5, Coppersmith Fall 2024crwdne2935289:0
UNT-COPPERSMITH-F24S2G5
crwdns2942667:0crwdne2942667:0 83
