eMachine T5234 RAM Disks Replacement
  1. eMachine T5234 RAM Disks Replacement, Shut Down Computer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Shut Down Computer: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Shut down the computer.
    • Disconnect all cables from the computer.
    • Static electricity can damage the hardware on your motherboard. Use the iFixit Anti-Static Wrist Strap or discharge the electricity by touching the metal of the case frame before unpacking the RAM disks.
    • Note: Do not remove the RAM disks from their casing until Step 8.
  2. eMachine T5234 RAM Disks Replacement, Removing the Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Removing the Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Removing the Case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Phillips #1 Screwdriver
    $5.49
    • Place the computer upright at standing position.
    • Using a Phillips #1 Screwdriver:
    • Remove the two 1cm combination screws located on the right of the casing.
  3. eMachine T5234 RAM Disks Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands, dislodge the casing and pull the case panel towards you until the panel comes off.
  4. eMachine T5234 RAM Disks Replacement, Locate the RAM Disk Slots: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Locate the RAM Disk Slots: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Locate the RAM Disk Slots: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the case panel open, locate the two RAM disk slots on the right side of the motherboard.
    • Do not touch the motherboard with your hands. The oil on your skin can damage or destroy the hardware modules.
  5. eMachine T5234 RAM Disks Replacement, Remove the RAM Disks: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Remove the RAM Disks: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the tabs on the RAM disks.
    • Use your index finger to release the tab at the bottom of the left RAM disk slot.
  6. eMachine T5234 RAM Disks Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the tab at the top of the left RAM disk.
    • Note: The RAM disk will pop off the motherboard when you release the bottom tab. Use the edges of the RAM disk to pick up and store the memory disk.
    • If the RAM disk does not pop off, use the edges of the disk to pull it off.
    • Store the unused RAM disk in a plastic container for future use or go to a recycling center for proper disposal.
  7. eMachine T5234 RAM Disks Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the top tab and the bottom tab to dislodge the right RAM disk.
  8. eMachine T5234 RAM Disks Replacement, Installing the RAM Disks: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove your new RAM disks from their casing.
    • Hold the RAM disk along the sides and avoid skin contact with any of the gold components.
  9. eMachine T5234 RAM Disks Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the RAM disk to match the slot and insert the disk to the right memory disk slot.
    • Gently push the disk in to secure.
    • Secure the tabs at the top and bottom of the memory disk slots to lock into place.
  10. eMachine T5234 RAM Disks Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now it's time for the second disk. Retrieve the second RAM disk from it's casing.
  11. eMachine T5234 RAM Disks Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the RAM disk to match the slot and Insert the RAM disk to the right memory disk slot
    • Secure the tabs at the top and bottom of the RAM disk to lock into place.
  12. eMachine T5234 RAM Disks Replacement, Reassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Reassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement, Reassembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use both hands to align the case panel to the case frame.
    • Once in place, push the case panel forward until it secures in place.
  13. eMachine T5234 RAM Disks Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 eMachine T5234 RAM Disks Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $5.49
    • Using your Phillips #1 Screwdriver:
    • Screw the two 1cm combination screws back into place on the right side of the case panel.
And that’s all there is to it! Make sure to dispose your old RAM disks properly at your local recycling center.
Luis Lopez
crwdns2935283:008/22/19crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 274
