eMac PRAM Battery Replacement
  1. eMac PRAM Battery Replacement, PRAM Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMac PRAM Battery Replacement, PRAM Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
  2. eMac PRAM Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMac PRAM Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The access panel is held in place by one Phillips screw. Unscrew it.
    • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
  3. eMac PRAM Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is located just to the left and below the RAM slots.
    • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
    • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
    • After removal of the old battery and replace with a new one by pressing it into place.
    • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
    • If no internet just set the date and time manually.
    • Next select the Time Zone box. Click the curser on the map to the closest city to you.
    • Next click the Clock box and select the type of display you prefer.
crwdns2935229:026crwdne2935229:0
mayer
crwdns2935283:001/04/10crwdne2935283:0
688,279 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
MacHale Enterprises crwdns2935289:0MacHale Enterprisescrwdne2935289:0
Business
crwdns2935297:019crwdne2935297:0
Alguien sabe el.modo serie de la batería???? Todo muy bien pero faltó lomas importante el modelo serie o número de pieza de la bateria
ru vera - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 23,898
