eMac PRAM Battery Replacement
    1. eMac PRAM Battery Replacement, PRAM Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMac PRAM Battery Replacement, PRAM Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
    2. eMac PRAM Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 eMac PRAM Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The access panel is held in place by one Phillips screw. Unscrew it.
      • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
    3. eMac PRAM Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery is located just to the left and below the RAM slots.
      • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
      • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
      • After removal of the old battery and replace with a new one by pressing it into place.
      • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
      • If no internet just set the date and time manually.
      • Next select the Time Zone box. Click the curser on the map to the closest city to you.
      • Next click the Clock box and select the type of display you prefer.
crwdns2935229:027crwdne2935229:0
mayer
crwdns2935283:001/04/10crwdne2935283:0
690,624 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Alguien sabe el.modo serie de la batería???? Todo muy bien pero faltó lomas importante el modelo serie o número de pieza de la bateria
ru vera - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 25,131
