In order to replace components like the CD drive, the motherboard access panel must first be removed.
It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
Remove the single phillips #2 screw on the RAM door, and remove the door
The screw is captive in the door, so don't worry about losing it.
You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
On the bottom side of the eMac, remove the following screws:
A single 2.5mm hex screw
Two #2 phillips screws
Remove two 2.5mm hex screws from each of the other sides of the computer.
Now, the shell can almost be separated from the computer.
Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
Now the entire shell can be removed from the computer.
The motherboard access panel is held on by 4 phillips #2 screws.
Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
