The Power Board is the board that charges the PS Move controllers. This is how you replace it.
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Remove the six 2 mm PH0 screws on the bottom of the device.
Gently remove the bottom of the device.
Remove the four 1.8 mm J1 screws.
Remove the two 2mm PH0 screws.
Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Remove the four 1.8 mm PH0 screws that are holding the board in.
Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
