in this guide we will replace a broken lcd cable.
we will also see how to open the laptop , so you can replace other parts..
if you want to replace a broken screen , start at step 17 -18
first remove the battery
remove the big cover , removing 3 screws
now , remove the DVD player by removing 1 screw.
Use a spudger to remove the dvd player.
remove the HDD bay and screws. ( 2 in my case..)
after removing the 2 black screws slide the HDD out.
now we will remove the screws from the case.
other screws from the case..
there are also 3 small screws hidden under the dvd bay. if you remove the dvd bay ( like in step before) you will see the 3 small screws. i don't have a picture of it.
now turn the laptop again and use a spudger te remove the upper case with the keyboard attached to it.
remove the ribbon cables from the connector on the main board.
use a flat head screwdriver or a small plastic spudger to lift the small plastic lever from the connector upwards.
slide the cables away from the connector when te lever is "open" , and close the small lever again.
after removing the upper case ( holding the keyboard) you will see the main board ...
if you want to replace the keyboard : the keyboard is attached to the upper case , remove the screws from the metal frame and remove the old keyboard. always be carefull with the ribbon cable..
now we will loosen the cable's from the main board.
remove the DC jack cable connected to the connector on the main board.
in the picture you see me using a IC axtractor, but i don't recommend it when you are not used to repair laptops...
when you are dealing with an broken DC jack , remove the whole cable ( black and red) running trough the plastic frame of the laptop...
remvinf the LCD cable from the connector , use a IC extractor , be very gently doing this.. when you break or tear it , you will have screen problems...
remove the small connector next to the big lcd connector, it is the web cam connector.
remove the white big flat ribbon cable attached to the USB ( on the right) PCB.
again be careful and use a flat head screwdriver or a spudger to lift up the lever..
remove the audio cable from the connector , be careful if you tear the cables , you will have audio problems and there is a possibility that you will have BSOD ( blue screen of death) ...
remove the FAN cable from the connector , be very carefull because it are very tiny and breakeble cables...
remove the 3 screws seen in picture 1
remove 1 screw on the left side from the LCD connector.
after that, you can slide the main board out. ( lift it up on the right side, then slide to the right and take it out. )
when you want to remove the fan as well ( or replace it) you have to remove 3 screws, see picture 3
after removing the main board you have a view of the henges from the screen.
in picture 2 you will see the main board. , you can clean and or replace the CPU now.
to replace a cpu or clean the pads you will have to remove the screws seen in picture 3 .
clean the pads with isopropyl alcohol and always renew the CPU thermal paste . ( one drop on each spot is enough)
remove the 3 screws on each hinge
on the right hinge there is a metal hook attached on the hinge. this is attached to the bottom case .. just move the screen to release it.
remove the black square rubber to reveal the hidden screws.
there are 2 screws one on the bottom left and one on the bottom right.
after removing the scrws you can slide a spudger or opening tool arround the plastic frame.
once the plastic frame is removed , you can replace the screen , the LCD cable..
i don't have pictures anymore when i was removing the screen .. my apologies for that. but you can follow other guides to do that , cause it is all the same...
