Zte Avail 2 Display Replacement
  1. Zte Avail 2 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zte Avail 2 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zte Avail 2 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zte Avail 2 Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zte Avail 2 Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zte Avail 2 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
crwdns2935229:05crwdne2935229:0
dunnluke
crwdns2935283:009/22/15crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-6, Sydow campbell Fall 2015 crwdns2935289:0University of Alabama, Team 1-6, Sydow campbell Fall 2015crwdne2935289:0
UA-SYDOW CAMPBELL-F15S1G6
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,042
