The chest sensor is needed for many of the device's functions, making it one of the device's most important features. This guide will go over the steps to remove and replace the sensor in case it becomes damaged.
Using the Triangle driver remove the four 7.5 mm screws.
Turn the device so that the the device is on its side.
Hold the back and belly on the device and gently pull apart.
With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
Carefully pry the ribbon cable from the connector.
For easier access to the sensor, tilt and pull the sensor away from the body.
To remove the sensors, use a soldering iron to solder the two points and remove the red and black wires from the reverse side.
Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of wires.
The sensor should be completely detachable now.
