Zoomer Meowzies Battery Replacement
  1. Zoomer Meowzies Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zoomer Meowzies Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zoomer Meowzies Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Mitchell Gentry
crwdns2935283:002/14/18crwdne2935283:0
693 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S6-G2, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S6-G2, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S6G2
crwdns2942667:0crwdne2942667:0 1,165
