Zoomer Jurassic World Indominus Rex Mouth Gears Replacement
  1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the tongue, inspect and remove any debris from the inside of the mouth.
    • Remove the four (4) 7.5mm phillips screws that are inhibiting your ability to successfully remove the motor inside the mouth.
    • Remove the two (2) 7.2mm phillips screws that fasten the motor to the inside of the mouth.
  4. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the motor assembly from the mouth and inspect for any apparent issues.
    • Use a #1 Phillips Screwdriver to remove the two (2) 5.5mm phillips screws to remove the motor from the rest of the assembly.
    • Use tweezers to gently remove the motor from the rest of the assembly.
  5. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, inspect the main output gear for the jaw and remove if necessary.
    • Remove the four (4) 4.9mm screws from the other side of the assembly.
    • Use a spudger to gently pry apart the assembly for inspection.
  6. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the gears inside the assembly and replace any gears that have flattened or rounded teeth.
Luke Selby
crwdns2935283:001/20/16crwdne2935283:0
636 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-3, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-3, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 775
