Zoom H1 Handy Recorder Speaker Replacement
  1. Zoom H1 Handy Recorder Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over with its display down.
  2. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
  4. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry up the top end of the back cover using one finger.
  5. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the white and black speaker wires from their soldering points.
    • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
    • Keep in mind which color wire was connected at which terminal.
  7. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
    • You will have to break the glue holding the speaker in place before removing it.
  8. Zoom H1 Handy Recorder Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the damaged speaker and re-solder to the original solder points.
    • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
Alex
crwdns2935283:010/28/13crwdne2935283:0
809 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,892
