Zoll Impact Uni-Vent 731 Power Knob Kit Replacement
  1. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement, Power Knob Kit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake
    • Pg. 29
  2. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator
    • Pg. 29
  3. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”
    • Pg. 29
  4. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module
    • Pg. 29
  5. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bezel by loosening and removing the (7) 4-40 X ¼ screws that hold the bezel to the front case
    • Pg. 29
  6. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the membrane panel assembly, loosen the 6-32 X ¼ set screw using a 1/16 Ball Hex Driver (located in the power knob) and lift the damaged knob from the membrane panel
    • Pg. 30
  7. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the replacement knob on the membrane panel switch -align with flat on switch –insert the included 6-32 X ¼ set screw and tighten
    • Pg. 30
  8. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new bezel by tightening the included (7) 4-40 X ¼ screws
    • Pg. 30
  9. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position
    • Pg. 30
  10. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws
    • Pg. 30
  11. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten the (4) 8-32 X 3 screws on the outer air intake
    • Pg. 30
  12. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS
    • Pg. 30
Emily
crwdns2935283:005/04/20crwdne2935283:0
206 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G5, Zimmerman Spring 2020 crwdns2935289:0Cal Poly, Team S1-G5, Zimmerman Spring 2020crwdne2935289:0
CPSU-ZIMMERMAN-S20S1G5
crwdns2942667:0crwdne2942667:0 222
