Zippo Lighter Felt Pad and Cotton Replacement
  1. Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the lid of the lighter.
    • Hold the bottom of the lighter’s case and pull out the metal container.
    • Set the case aside for now.
  2. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the metal container upside down with the bottom facing you.
    • You should see a piece of white felt with the words “Lift to fill.”
  3. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the screw with a flathead screwdriver.
    • There is a spring behind the screw, so make sure you are unscrewing slowly and gently.
    • Remove the screw with the spring and the flint attached to it.
  4. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the felt pad up and out of the metal container using a pair of tweezers.
  5. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the old cotton from the inside.
    • When adding new cotton, it should fully cover the inside of the metal canister.
    • Throw the old felt and cotton in the garbage.
  6. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to push each cotton piece on top of the wick inside the metal container. Make sure the cotton pieces cover all the sides.
  7. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to place the new felt pad on top of the cotton pieces.
  8. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the flint and screw it back into place using a flathead screwdriver.
  9. Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zippo Lighter Felt Pad and Cotton Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Refuel your lighter, put the metal container back inside the case, and test out the lighter.
    • Only use the lighter when it is secured inside the case.
    When you repack a Zippo you actually want to make sure that you snake the wick in between every piece of cotton until the wit comes all the way to the bottom of the metal case but you want to be careful not to pinch the wick at any point especially up near the chimney where it comes out to be lit. Let the wick should snag all the way through the metal case to ensure it absorbs all the liquid from all the cotton. It will last a whole lot longer between refills.
    Edward Vaughn Wahner - crwdns2934203:0crwdne2934203:0
    If you want to know the very best way to repack the cotton in your Zippo I would watch this video from this guy who really knows his stuff when it comes to Zippo lighters.
    https://youtu.be/QKHgsNUFzOw
Dara
crwdns2935283:010/01/21crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
York University, Team G-35, O'Regan Fall 2021 crwdns2935289:0York University, Team G-35, O'Regan Fall 2021crwdne2935289:0
YORK-O'REGAN-F21SGG35
How do you put a wick in zippo when there is none?
Joan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 137
crwdns2942667:0crwdne2942667:0 10,986
