Zerodate T26 RGB LED Replacement
crwdns2869540:0crwdne2869540:0: 508
10
61
508
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:020crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
Are the lights of your Zerodate T26 mouse not functioning when the mouse is on and otherwise working? If so, here’s the guide on replacing your mouse's RGB lights. All you need is a plastic opening tool to gently pry the top, a Phillips #00 screwdriver to open the mouse, and a soldering iron to begin replacing. New LEDs can be purchased online.
    1. Zerodate T26 RGB LED Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zerodate T26 RGB LED Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
    2. Zerodate T26 RGB LED Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zerodate T26 RGB LED Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
      • Adhesive pads are located on the bottom of the mouse.
    3. Zerodate T26 RGB LED Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zerodate T26 RGB LED Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
    4. Zerodate T26 RGB LED Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zerodate T26 RGB LED Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the middle shell apart from the bottom plate.
      • The circuit board should then be visible and attached to the bottom plate.
    5. Zerodate T26 RGB LED Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zerodate T26 RGB LED Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the scroll wheel by pushing it to the right and pulling up.
    1. Zerodate T26 RGB LED Replacement, RGB LED: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zerodate T26 RGB LED Replacement, RGB LED: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zerodate T26 RGB LED Replacement, RGB LED: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the battery from the circuit board.
      • Use the precision tweezers to remove the tape from the circuit board.
      • Carefully pull apart the circuit board from the bottom shell.
    2. Zerodate T26 RGB LED Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the LEDs from the circuit board and solder on the new LEDs following the soldering guide.
      • Please be sure to review safety guidelines and guided steps on soldering/desoldering before attempting remove of LEDs
Janice Rullan
crwdns2935283:003/13/23crwdne2935283:0
662 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-3, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 2-3, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S2G3
crwdns2936753:030crwdne2936753:0 61
crwdns2959996:0crwdne2959996:0 508
