This guide requires three prerequisite guides for the proper replacement of the digitizer screen on the front of the Zeki tablet. Please, take a moment to familiarize yourself with those guides. They can be found in the details section of this guide.
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Place the tablet down so that the screen is facing away from you.
Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
Gently work your way around the perimeter of the tablet's edge.
Remove the back cover
Remove any tape on the speaker and detach the speaker from the back plate.
Disconnect the Wi-Fi antenna cable from the motherboard.
Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
Disconnect the other ZIF connector on the opposite side of the motherboard.
Remove the motherboard and now reinsert all connectors into a new motherboard.
Use an opening tool to detach the clip between the front frame, and the metal loader.
Lift the metal loader up and separate it from the LCD screen.
Separate the display from the digitizer.
