Zeki TBQG884B Camera Replacement
  1. Zeki TBQG884B Camera Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zeki TBQG884B Camera Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zeki TBQG884B Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zeki TBQG884B Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
Natalie Holm
crwdns2935283:009/16/15crwdne2935283:0
146 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-3, Harley Fall 2015 crwdns2935289:0IUPUI, Team 1-3, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S1G3
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 324
