If there is no audio coming from your device's speaker, then there are several ways to fix this issue. In this following guide, you can find several step-by-step solutions to fix, or replace, a damaged speaker.
Using a plastic spudger, remove the back casing of the device.
You must first carefully remove any tape from the speaker and connecting wires.
Next, remove the wires from the motherboard.
