If for any reason your device has been dropped, damaged, or cracked, then it could interfere with the sensitivity of the screen. If this happens to be the case, then here's a solution to replace a damaged display.
Using the plastic spudger, remove the back casing of the device (it will snap off).
Using a #000 1.5 mm Phillips screwdriver, remove the screws along the inside of the device(there is two screws under the motherboard, do not forget those).
At this point, you should be able to remove the display.
