This guide will be instructing someone on how to access and replace the screen. A few tools will be used to open the device, the wires connecting to the motherboard from the LED screen will be cut, and now the screen can be removed from the outer casing.
Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
Disconnect the two ribbon cables between the screen and the motherboard.
Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
Separate the LCD screen from the metal protecting case with the metal spudger.
After creating space to work, warm up a soldering iron.
Apply heat onto the solder over the corresponding cut wires to the new screen wires.
To reassemble your device, follow these instructions in order.
where do you buy the screen?
i need a battery an a screen? is their a place on this page where to get them?
