Use the following guide to remove the ZP 505 feed key using a phillips head screwdriver set.
Remove the following screws securing the top case to the ZP 505.
Six P1 9.0mm
One P0 19.0mm
Close the printer and remove the top cover.
Carefully remove the ribbon cables from feed key.
Remove the two P0 6mm screws securing the feed key.
Lift and remove the feed key from the printer.
