ZTE ZMAX Z970 Power Button Replacement
  1. ZTE ZMAX Z970 Power Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Power Button Replacement, Power Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement, Power Button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement, Power Button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black tape covering the motherboard.
    • Remove the single 1.2mm screw with a Phillips #000 screwdriver.
  8. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of the spudger to release the upper left and right prongs that secure the motherboard.
    • Detach the antenna cable.
  9. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the tan flap on the three ZIF connectors.
    • Pull the ribbon out of the now unlocked ZIF connectors.
  10. ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE ZMAX Z970 Power Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the covering panel below the motherboard covering and connecting the power button.
    • Disconnect the circuit tape of the power button and remove the power button.
    • The power button in these photos has been damaged and not soldered to the motherboard.
    • The new power button will have to be desoldered to the mother board.
Burak Cengiz
crwdns2935283:002/15/18crwdne2935283:0
480 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S17-G3, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S17-G3, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S17G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 601
