The step-by-step guide will instruct users on how to replace the front speaker on the ZTE Tempo smartphone. The speaker will need to be replaced if any audio issues are occurring. This guide will provide details on opening the phone’s back case and removing the front speaker inside the phone. This task requires an opening tool, tweezers, and a Phillips #0 screwdriver.
Use a plastic opening tool to pry open the back case.
Use a Phillips #0 screwdriver to remove the eight 5mm screws.
Use a plastic opening tool to remove the midframe.
Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
Lift the battery up and remove it from the phone.
Use a plastic opening tool to unplug the wires by pulling them to the side.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use metal tweezers to remove the front speaker.
