If the battery in your phone dies quickly, it may be time for a new one. By following this guide, you will learn how to remove the battery in a ZTE Tempo and replace it with a new battery. By replacing the battery, the charge will last longer, and the overall function of the phone will increase in quality.
Use a plastic opening tool to pry open the back case.
Use a Phillips #0 screwdriver to remove the eight 5mm screws.
Use a plastic opening tool to remove the midframe.
Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
Lift the battery up and remove it from the phone.
