ZTE Quest n817 Power/Volume Button Replacement
  1. ZTE Quest n817 Power/Volume Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Quest n817 Power/Volume Button Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Quest n817 Power/Volume Button Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Power/Volume Button Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Quest n817 Power/Volume Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
  9. ZTE Quest n817 Power/Volume Button Replacement, Power/Volume Button: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Each of these buttons can be removed using micro-soldering techniques around either side of the button.
    • Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
Eric Loureiro
crwdns2935283:010/26/18crwdne2935283:0
606 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G6, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S3-G6, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S3G6
crwdns2942667:0crwdne2942667:0 367
