If your ZTE Quest's power and/or volume buttons aren't working properly then it may be necessary to replace them. This guide requires extensive soldering knowledge and should really only be attempted as a last resort.
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Use the ribbon to remove the exposed battery.
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
Carefully pry open the back panel with the plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
Pull back the tape encasing the brown ribbon cable connector.
Remove the ribbon cable from its socket.
Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
Disconnect the coaxial connector in the bottom right corner of the motherboard.
Each of these buttons can be removed using micro-soldering techniques around either side of the button.
Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
