ZTE Quest n817 Daughterboard Replacement
  1. ZTE Quest n817 Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Quest n817 Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Quest n817 Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Quest n817 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Daughterboard Replacement, Daughterboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry open the back panel with the plastic opening tool.
  4. ZTE Quest n817 Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
  5. ZTE Quest n817 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.0mm screws on either side of the daughterboard.
  6. ZTE Quest n817 Daughterboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the coaxial connector that links the daughterboard to the motherboard.
Eric Loureiro
crwdns2935283:010/26/18crwdne2935283:0
606 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G6, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S3-G6, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S3G6
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 335
