ZTE Max XL Battery Replacement
  1. ZTE Max XL Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Max XL Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before any disassembly, make sure the phone is powered off.
    • Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
  2. ZTE Max XL Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
    • On the phone shown there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at one corner, wedge the plastic opening pick underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom, and 6 on each side.
    • Use extreme caution to not puncture the lithium ion battery.
  4. ZTE Max XL Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing.
    • There are two 3.4mm JIS 00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS 00 screwdriver.
  5. ZTE Max XL Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
  6. ZTE Max XL Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver.
  7. ZTE Max XL Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening pick between the screen and side trim battery cover to remove the screen.
    • If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
  8. ZTE Max XL Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the top left of the battery, flip the metal clips with a pick and remove the battery ribbon from the shell.
  9. ZTE Max XL Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
    • Use extreme caution to not overheat the battery. Never use any open flames or high heat.
    • Adhesive is used to secure the battery to the phone. If you're having problems you may need to heat the screen as well.
  10. ZTE Max XL Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Max XL Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit opening tools carefully pry the edges of the battery away from the casing.
    • While prying, take care to not scrape the wires underneath the battery.
  11. ZTE Max XL Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery removed, you can now insert the new battery or replace other parts within your phone.
crwdns2935229:08crwdne2935229:0
Olivia Wolf
crwdns2935283:002/15/18crwdne2935283:0
1 400 crwdns2915208:0crwdne2915208:0
UW Stout, Team S8-G2, Ogden Spring 2018 crwdns2935289:0UW Stout, Team S8-G2, Ogden Spring 2018crwdne2935289:0
UWSTOUT-OGDEN-S18S8G2
Thank you for the help
I had it done in no time.
finchcolumbus - crwdns2934203:0crwdne2934203:0
So I replaced my fine no issues tries to do my husband's and punctured the battery and now the touch is not working any ideas on what happened and how to fix it?
melissamudd8292 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,520
