ZTE Maven 3 Screen Replacement
    1. ZTE Maven 3 Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Maven 3 Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Maven 3 Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the small indent on the back right bottom corner of the phone.
      • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
      • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
    1. ZTE Maven 3 Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Maven 3 Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Maven 3 Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the battery in the middle of the back of the phone.
      • Push in and up on the battery to remove it from its slot.
      • Put the battery aside.
    1. ZTE Maven 3 Screen Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
    2. ZTE Maven 3 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
    3. ZTE Maven 3 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 3 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
      • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
      • The detached piece is the midframe, and you can place it aside when detached.
    1. ZTE Maven 3 Screen Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
    2. ZTE Maven 3 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Please locate the black wire that’s attached to gold plates on the left side of the device.
      • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
    3. ZTE Maven 3 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 3 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
      • 2 adhesive ribbon cables (green circles).
      • One ribbon cable that slides out (orange circles).
      • Three ribbon cables that pop in and out (yellow circles).
    4. ZTE Maven 3 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Maven 3 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Maven 3 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
    5. ZTE Maven 3 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 3 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the opening pick and work it into the edges of the motherboard.
      • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
      • Remove the motherboard and put it aside.
    1. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
    1. ZTE Maven 3 Screen Replacement, Screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
Emma Thiboutot
crwdns2935283:010/30/23crwdne2935283:0
705 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-1, Konn Fall 2023 crwdns2935289:0UMass Dartmouth, Team 3-1, Konn Fall 2023crwdne2935289:0
UMASSD-KONN-F23S3G1
crwdns2935297:0120crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 369
