crwdns2959928:0crwdne2959928:0 ↓Follow this replacement guide to replace the power button on a ZTE Lever smartphone.
Remove the SD card and the Sim card from the device.
Use an iFixit opening tool to separate the back from the device.
Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
Remove the cover.
Disconnect the battery cable from the motherboard with a plastic opening tool.
Use your hands, or a plastic opening tool, to pry the battery from the phone.
Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
Remove the top plastic motherboard cover using a plastic opening tool.
Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
Peel up the volume button cable from the phone with hands, or plastic opening tool.
Disconnect the power button from the motherboard with a plastic opening tool.
Peel the power button cable up from the phone with you hands, or a plastic opening tool.
