Battery replacement guide for ZTE jasper LTE. Follow the guide’s procedure if the battery fails to charge.
Insert the spudger into the bottom left corner of the phone.
Use the spudger to loosen the back cover.
Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
Continuing to use tool, prop up the battery and remove it.
