The ZTE Compel features a rechargeable lithium ion battery. You may need to replace the battery if it no longer holds a charge, if the battery is corroded, or if you are simply force restarting your phone. Please take all necessary precautions, such as protective gloves and eyewear if dealing with battery corrosion.
Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
