ZTE Blade Spark Rear-Facing Camera
  1. ZTE Blade Spark Rear-Facing Camera, ZTE Blade Spark Rear-Facing Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, apply heat evenly on the back cover using a heat sack to soften the adhesive.
  2. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now, carefully remove the back cover.
  3. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once opened, Locate and remove all exposed screws using a Phillips-Head screwdriver and set them aside.
  4. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the white plastic panel, you should see a black metal battery cover.
    • To remove the metal battery cover, remove the screws from the panel using a Phillips screwdriver if you have not yet done so.
  6. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, simple lift to remove the metal battery cover.
  7. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You have reached the Fingerprint Scanner, the device Battery, and Front Facing Camera.
  8. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Blade Spark Rear-Facing Camera: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Blade Spark Rear-Facing Camera: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Proceeding with disassembly, next up is the top chipset which the Rear Facing Camera is attached to.
    • To detach the chipset and reach the Rear Camera, locate and disconnect five power connectors surrounding the top chipset (as shown in images).
  9. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have the power connectors disconnected from the top chipset, use a Phillips screwdriver to remove the final screw located at the very top of the chipset (as shown in image).
  10. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, simply lift chipset from top and detach from the device frame.
  11. ZTE Blade Spark Rear-Facing Camera: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You have now reached the final replacement component of the device, the Rear Facing Camera!
    • For step-by-step instructions on replacing any of the device components covered throughout the disassembly process, check out our ZTE Blade Spark Replacement guides.
Hung Vu
crwdns2935283:001/24/18crwdne2935283:0
632 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G6, Johnson Spring 2018 crwdns2935289:0Gateway, Team S1-G6, Johnson Spring 2018crwdne2935289:0
GCC-JOHNSON-S18S1G6
crwdns2942667:0crwdne2942667:0 2,509
