crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0ZEBCO 202kcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. ZEBCO 202k Teardown, ZEBCO 202k Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove front cover assembly (red cap)
    • turn assembly cap counterclockwise
  2. ZEBCO 202k Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Takeoff spinner head assembly. (metal cap)
    • Hold the handle and turn spinner head assembly counterclockwise
  3. ZEBCO 202k Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use flat head to remove the spool clip
    • remember order of washers for assembly.
    • after removing spool clip washer, you can also pull out spool
  4. ZEBCO 202k Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Underneath the spool there will be a thin washer and a drag adjuster spring.
    • lift up to remove
  5. ZEBCO 202k Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat head unscrew drag actuator.
    • Will need to hold the drag nob down to keep it from moving.
  6. ZEBCO 202k Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove back assembly from body assembly by pushing up oppisites side off handle
    • no tools are needed
  7. ZEBCO 202k Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove spring from center shaft by pulling it by hand or help of flat head
    • center shaft will fall from the middle
  8. ZEBCO 202k Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • unscrew handle to remove driven gear and to remove anti reverse.
  9. ZEBCO 202k Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • insert driven and anti revers screw and reconnect handle.
  10. ZEBCO 202k Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • slide in back assembly
    • screw in drag nob and drag actuator
  11. ZEBCO 202k Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZEBCO 202k Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • insert drag adjuster spring
    • then thin washer
    • spool then red washer and the last whasher
    • at the top you will need to clip in spool clip.
  12. ZEBCO 202k Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • turn spinner head assembly till lock into place
    • put front cover assembly back on
crwdns2935103:0crwdne2935103:0
Daniel
crwdns2935283:009/09/24crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 157
