ZCWA BR151 Wheel Replacement
  1. ZCWA BR151 Wheel Replacement, Water Tank: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the device.
  2. ZCWA BR151 Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Wheel Replacement, Wheel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Wheel Replacement, Wheel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
  4. ZCWA BR151 Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
    • Remove the bumper guards by lifting them.
  5. ZCWA BR151 Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
  6. ZCWA BR151 Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
  7. ZCWA BR151 Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the bottom panel off of the top.
    • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
    • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
  8. ZCWA BR151 Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
    • Pinch the wire bracket that is on the top panel while pulling the bracket away.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  9. ZCWA BR151 Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZCWA BR151 Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZCWA BR151 Wheel Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the single screw to the spring.
    • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
  10. ZCWA BR151 Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Wheel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
    • Pinch the silver brackets and pull the wire casing away from the motherboard.
    • Remove the wheel from the vacuum.
    • Repeat Steps 6-10 to replace the wheel on the opposite side.
Gavin H. Stackhouse
crwdns2935283:001/31/24crwdne2935283:0
375 crwdns2915208:0crwdne2915208:0
Tennessee Tech University, Team 1-1, Pickering Spring 2024 crwdns2935289:0Tennessee Tech University, Team 1-1, Pickering Spring 2024crwdne2935289:0
TNTECH-PICKERING-S24S1G1
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 420
