The ZCWA BR151’s water tank holds the water necessary for its mopping capabilities. If the device is leaking water, refer to the troubleshooting page for instructions on how to correct this. If the water tank of the ZCWA BR151 needs to be replaced, use this guide to do so. It is easy to access through the removal of only a few pieces. No tools are needed to replace or install the water tank. There are no difficult steps in these instructions.
Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
Pull it out.
