ZCWA BR151 Battery Replacement
  1. ZCWA BR151 Battery Replacement, Water Tank: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the device.
  2. ZCWA BR151 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over to access the panels on the back.
    • Rotate the device to where the battery panel is closest to you.
    • Using a Phillips #1 screwdriver, remove the two 10 mm screws from the battery panel.
  4. ZCWA BR151 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From the opposite end of the battery wires, use an opening tool to pry the battery out.
    • Do not use metal objects to pry out the battery.
    • You may need to rotate the device depending on your hand prominence.
  5. ZCWA BR151 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the electrical tape that wraps around the battery's wire connectors.
  6. ZCWA BR151 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZCWA BR151 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the two lock mechanisms on the wire connectors while pulling them apart.
    • Set aside the old battery to dispose of later.
    • Batteries can be safely disposed of at your local recycling center with the help of a professional.
Kaitlyn Baltz
crwdns2935283:001/22/24crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
Tennessee Tech University, Team 1-1, Pickering Spring 2024 crwdns2935289:0Tennessee Tech University, Team 1-1, Pickering Spring 2024crwdne2935289:0
TNTECH-PICKERING-S24S1G1
Where to buy the replacement battery and what is the part number
Andre Bellanger - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 80
crwdns2942667:0crwdne2942667:0 764
