If you need to install a new battery in your ZCWA BR151 vacuum, you can access the battery panel on the underside of the device using this guide. The battery is easily accessible, so there is no need to remove any additional parts to access it. You will not need to do any difficult steps, but extract the battery carefully.
Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
Pull it out.
Flip the device over to access the panels on the back.
Rotate the device to where the battery panel is closest to you.
Using a Phillips #1 screwdriver, remove the two 10 mm screws from the battery panel.
From the opposite end of the battery wires, use an opening tool to pry the battery out.
Peel off the electrical tape that wraps around the battery's wire connectors.
Pinch the two lock mechanisms on the wire connectors while pulling them apart.
Set aside the old battery to dispose of later.
Ok cool I hope it works
Blueobear - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where to buy the replacement battery and what is the part number
Andre Bellanger - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Myra Mitchell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
