Drone repairs are focused on the internal components, sometimes external parts like the legs take the most wear and tear. Whether it's from a hard landing or accidental bumping during storage, a damaged leg can affect the stability and may even prevent the drone from taking off properly. Replacing a damaged leg is an easy and essential repair that will restore the drone's support and ensure safe flights.
Flip the drone upside down.
Use a 2 mm Hex screwdriver to remove the two screws that secure the legs to the drone.
Turn the drone to the side so that you can get better grip.
Put both thumbs on the plastic clamp and detach the legs from the main body.
Repeat same steps for other leg.
