Is the camera on your Yuneec Breeze 4K Drone not recording? Consider using this guide to replace the camera in your drone.
Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
Once the battery is taken out, flip over the drone so that the cameras are now facing up.
Using small pliers grip the connector of the wire and pull it out slowly.
Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
Unplug the two vertical plugs located in the rear of the M7 board.
Slightly lift the M7 board to remove the two plugs located under the rear of the board.
Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
Using a pair of pliers pull apart the battery connector.
Flip over the entire frame along with the M7 board and the A9 board.
There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
Unplug the only wire that is connected to the A9 board.
Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
Unscrew the four screws that are holding the camera to the frame.
crwdns2917034:0crwdne2917034:0
Excellent! I don’t think that the process could of have been any more clear than this.
