This guide will teach you how to replace the filter.
Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
Empty contents of bin into waste receptacle and rinse with water as needed.
Push the yellow tab releasing the filter harness.
Replace or clean filter under a stream of water. When reinserting filter, make sure the filter's cut corner is in the correct corner.
To finish reassembling your device, follow these instructions in reverse order.
