Replacing the battery is a quick and easy fix if your robot exhibits the symptoms shown in the accompanying troubleshooting section.
Locate and unscrew the two 15mm screws with a Phillips #2 screwdriver.
Remove both screws shown by rotating them counter-clockwise.
Remove the battery compartment's lid.
Slide the battery out, and disconnect it from the robot by squeezing the tab on the power cable.
Tried 2 different new batteries and still won’t charge
