Yoto Mini SD Card Replacement
  1. Yoto Mini SD Card Replacement, SD Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you start disassembly, format the new card as FAT / FAT32
  2. Yoto Mini SD Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yoto Mini SD Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a very thin flat head screwdriver to pry out the two orange knobs on the front. They require a bit of force to remove. Then use a pair of pliers to grab the nuts and unscrew them. Set them aside with their washers and knobs somewhere safe.
  3. Yoto Mini SD Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the silicon feet – they’re just sticky. Unscrew the 2 Phillips head screws from under the feet pads and put them somewhere safe. These have flush/flat heads.
  4. Yoto Mini SD Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a very thin flat head screwdriver to gently pry open all around the edge. You might have to do some scary feeling tugging to get the top part. Be as gentle as you can but it came apart after some careful maneuvering to get the latches undone with the screwdriver as a lever.
  5. Yoto Mini SD Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you will see the battery pack. Maybe this is replaceable to fix the recall issue? No idea, that’s another project. There are two screws, one on each side. These are raised Phillips head. Unscrew them and put them somewhere safe, preferably labeled so you remember which goes where.
  6. Yoto Mini SD Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yoto Mini SD Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 4 more screws under the pack that willneed to be removed. Be careful with the battery so you don’t damage it. You may want to unplug it from its little socket. Mine was glued on so I completed the remaining steps with it still attached to the board.
    The screws circled in the picture is a little off - the top left corner isn't a screw, it's one of the posts to the screen assembly that are removed in the next step. The fourth screw is in the center.
    James Hartman - crwdns2934203:0crwdne2934203:0
  7. Yoto Mini SD Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yoto Mini SD Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The SD card slot is underneath the screen. The screen unit itself unfortunately it held on with 4 small plastic bits that go through the board. I had to cut off the tiny bits that went through – use an exacto knife or your small flathead screwdriver. Once those 4 bits were removed, the screen and holder easily came off.
    You can actually just pick off some of the white glue on the back of those tabs and wiggle the screen off gently! No need to cut!
    Lindsey Schultz - crwdns2934203:0crwdne2934203:0
  8. Yoto Mini SD Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Underneath, the SD card is in a hinged case. Use a fingernail to gently push the top of the casing back to unlock, then lift. Remove the SD card and replace in the same orientation, making sure the notches match up. Close and slide the hinge top forward to lock it.
  9. Yoto Mini SD Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screen. and put it all back together in the opposite order. Be aware that the screen holder will no longer be completely attached since you broke the 4 little tabs. Be careful reassembling so that it lines up correctly with the front panel. Same for the speaker.
  10. Yoto Mini SD Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw it back together. Replace the battery pack. Slide the back together, replace the feet screws, washers nuts and knobs, and silicon feet. You may have to finish with a factory reset – I didn’t have to.
  11. Yoto Mini SD Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Of note: The files on the previous SD card do not have extensions, but are nested in folders per-card and are playable as MP3 if you add “.mp3” to the filenames. It’s an interesting way to get to the files themselves if you’re inclined.
Max Elman
crwdns2935283:004/13/24crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
Exactly the guide ive been looking for thank you!. Havnt taken ours apart just yet to replace the SD card but do you think there is any room in there to wedge an AirTag? child keeps taking clipped on airtags off so looking for more options to track it down in the house 🤣
Sam Gutentag - crwdns2934203:0crwdne2934203:0
In Step 5 there are four screws, but the fourth one is right in the center of the logic board, not on the corner.
Chris Nelson - crwdns2934203:0crwdne2934203:0
I fixed the image, thanks
Max Elman -
I think the charging port is dead on ours. Think I can replace it?
Gabriel Amalfi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 129
crwdns2942667:0crwdne2942667:0 2,927
